This is what I wanted to avoid. Manual editing of the printer machine g-code. First of all, I am not sure how to do it. E.g. start code has section
;===== nozzle load line ===============================
G29.2 S1 ; ensure z comp turn on
G90
M83
G1 Z5 F1200
G1 X270 Y-0.5 F60000
G28.14 R0
G29.2 S0
G91
G1 Z0.8 F1200
G90
G1 X250 F60000
M109 S{nozzle_temperature_initial_layer[initial_no_support_extruder]}
M83
{if (filament_type[initial_no_support_extruder] == "TPU")}
G1 E5 F{filament_max_volumetric_speed[initial_no_support_extruder]/2.4053*60}
{endif}
G1 X290 E10 F{filament_max_volumetric_speed[initial_no_support_extruder]/2.4053*60}
G91
G3 Z0.4 I1.217 J0 P1 F60000
G90
M83
;===== noozle load line end ===========================
seems to be the section to deal with, BUT “noozle” at the end of the section confuses me - ok if it just a comment, not ok if it somehow used to identify blocks of the code.
This is clear that nozzle’s temp is not a perfect constant, and it will be fluctuating a little. I need printer to ensure that, before proceeding to **wipe tower** and then to the part, it waits for nozzle to reach temp, and have it stabilized for some time (have no significant temp overshoot).
Alternatively, I think it would be acceptable for printer NOT to cool down the nozzles at all putting over-heated plastic onto the wipe tower before going to the part.
Update: here’s the code from “change filament” section
;======== H2D ========
;===== 20260116 =====
M993 A2 B2 C2 ; nozzle cam detection allow status save.
M993 A0 B0 C0 ; nozzle cam detection not allowed.
{if (filament_type[next_extruder] == "PLA") || (filament_type[next_extruder] == "PETG")
|| (filament_type[next_extruder] == "PLA-CF") || (filament_type[next_extruder] == "PETG-CF")}
M1015.4 S1 K0 ;disable E air printing detect
{else}
M1015.4 S0 ; disable E air printing detect
{endif}
M620 S[next_extruder]A
M1002 gcode_claim_action : 4
M204 S9000
G1 Z{max_layer_z + 3.0} F1200
M400
M106 P1 S0
M106 P2 S0
{if toolchange_count == 2}
; get travel path for change filament
;M620.1 X[travel_point_1_x] Y[travel_point_1_y] F21000 P0
;M620.1 X[travel_point_2_x] Y[travel_point_2_y] F21000 P1
;M620.1 X[travel_point_3_x] Y[travel_point_3_y] F21000 P2
{endif}
{if ((filament_type[current_extruder] == "PLA") || (filament_type[current_extruder] == "PLA-CF") || (filament_type[current_extruder] == "PETG")) && (nozzle_diameter[current_extruder] == 0.2)}
M620.10 A0 F74.8347 L[flush_length] H{nozzle_diameter[current_extruder]} T{flush_temperatures[current_extruder]} P[old_filament_temp] S1
{else}
M620.10 A0 F{flush_volumetric_speeds[current_extruder]/2.4053*60*0.8} L[flush_length] H{nozzle_diameter[current_extruder]} T{flush_temperatures[current_extruder]} P[old_filament_temp] S1
{endif}
{if ((filament_type[next_extruder] == "PLA") || (filament_type[next_extruder] == "PLA-CF") || (filament_type[next_extruder] == "PETG")) && (nozzle_diameter[next_extruder] == 0.2)}
M620.10 A1 F74.8347 L[flush_length] H{nozzle_diameter[next_extruder]} T{flush_temperatures[next_extruder]} P[new_filament_temp] S1
{else}
M620.10 A1 F{flush_volumetric_speeds[next_extruder]/2.4053*60*0.8} L[flush_length] H{nozzle_diameter[next_extruder]} T{flush_temperatures[next_extruder]} P[new_filament_temp] S1
{endif}
{if long_retraction_when_cut}
M620.11 P1 I[current_extruder] E-{retraction_distance_when_cut} F{max((flush_volumetric_speeds[current_extruder]/2.4053*60), 200)}
{else}
M620.11 P0 I[current_extruder] E0
{endif}
{if long_retraction_when_ec}
M620.11 K1 I[current_extruder] R{retraction_distance_when_ec} F{max((flush_volumetric_speeds[current_extruder]/2.4053*60), 200)}
{else}
M620.11 K0 I[current_extruder] R0
{endif}
M620.15 C{new_filament_temp - filament_cooling_before_tower[next_extruder]}
M628 S1
{if filament_type[current_extruder] == "TPU"}
M620.11 S0 L0 I[current_extruder] E-{retraction_distances_when_cut[current_extruder]} F{max((flush_volumetric_speeds[current_extruder]/2.4053*60), 200)}
{else}
{if (filament_type[current_extruder] == "PA") || (filament_type[current_extruder] == "PA-GF")}
M620.11 S1 L0 I[current_extruder] R4 D2 E-{retraction_distances_when_cut[current_extruder]} F{max((flush_volumetric_speeds[current_extruder]/2.4053*60), 200)}
{else}
M620.11 S1 L0 I[current_extruder] R10 D8 E-{retraction_distances_when_cut[current_extruder]} F{max((flush_volumetric_speeds[current_extruder]/2.4053*60), 200)}
{endif}
{endif}
M629
{if (filament_type[current_extruder] == "TPU" || filament_type[next_extruder] == "TPU") && (old_extruder_variant != "Direct Drive TPU High Flow")}
M620.11 H2 C331
{else}
M620.11 H0
{endif}
{if (old_extruder_variant == "Direct Drive TPU High Flow") && (filament_map[current_extruder] == 2) && (filament_map[next_extruder] == 1)}
;debug log pe:{previous_extruder} ce:{current_extruder} ne:{next_extruder} oev: {old_extruder_variant} nev:{new_extruder_variant}
;debug fm-curr:{filament_map[current_extruder]} fm-next:{filament_map[next_extruder]}
;sw from R2L&TPU kit, travel run a distance for sketch TPU
G1 X30 Y30 F5000
M400
G1 X300 Y30 F5000
M400
{endif}
T[next_extruder]
;deretract
{if filament_type[next_extruder] == "TPU"}
{else}
{if (filament_type[next_extruder] == "PA") || (filament_type[next_extruder] == "PA-GF")}
;VG1 E1 F{max(new_filament_e_feedrate, 200)}
;VG1 E1 F{max(new_filament_e_feedrate/2, 100)}
{else}
;VG1 E4 F{max(new_filament_e_feedrate, 200)}
;VG1 E4 F{max(new_filament_e_feedrate/2, 100)}
{endif}
{endif}
; VFLUSH_START
{if flush_length>41.5}
;VG1 E41.5 F{min(old_filament_e_feedrate,new_filament_e_feedrate)}
;VG1 E{flush_length-41.5} F{new_filament_e_feedrate}
{else}
;VG1 E{flush_length} F{min(old_filament_e_feedrate,new_filament_e_feedrate)}
{endif}
SYNC T{ceil(flush_length / 125) * 5}
; VFLUSH_END
M1002 set_filament_type:{filament_type[next_extruder]}
M400
M83
{if next_extruder < 255}
M620.10 R{new_extruder_retracted_length}
M628 S0
;VM109 S[new_filament_temp]
M629
M400
;prime_tower_interface
{if is_prime_tower_interface && filament_tower_interface_purge_volume !=0}
G150.1
M620.13 W0 L{filament_tower_interface_purge_volume} T{filament_tower_interface_print_temp} R0.0
{endif}
M983.3 F{filament_max_volumetric_speed[next_extruder]/2.4} A0.4 R{new_extruder_retracted_length}
M400
{if wipe_avoid_perimeter}
G1 Y320 F30000
G1 X{wipe_avoid_pos_x} F30000
{endif}
G1 Y295 F30000
G1 Y265 F18000
G1 Z{max_layer_z + 3.0} F3000
{if layer_z <= (initial_layer_print_height + 0.001)}
M204 S[initial_layer_acceleration]
{else}
M204 S[default_acceleration]
{endif}
{else}
G1 X[x_after_toolchange] Y[y_after_toolchange] Z[z_after_toolchange] F12000
{endif}
M621 S[next_extruder]A
M993 A3 B3 C3 ; nozzle cam detection allow status restore.
{if (filament_type[next_extruder] == "TPU")}
M1015.3 S1;enable tpu clog detect
{else}
M1015.3 S0;disable tpu clog detect
{endif}
M1015.4 S1 K1 H[nozzle_diameter] ;enable E air printing detect
{else}
{endif}
M620.6 I[next_extruder] W1 ;enable ams air printing detect
M1002 gcode_claim_action : 0
VM109 S[new_filament_temp]” ???
And I do not see explicit nozzle change section.
