I’m trying to dial in the settings necessary for Bambu’s TPU 95A filament. I’m wanting to change the Nozzle temp but regardless of what I set the Filament Nozzle Temp to the printer always sets the temp to 255º. I’ve been changing it manually using the touch screen but I’m wanting to know what I’m missing. Why can’t I change the Nozzle Temp and save it in the Filament settings?
Below is what the printer is setting the Nozzle at when printing:
Ok so I’ve lock my settings in a 200. That was my intent. Why is the printer still setting the Nozzle Temp to 255? And what is the “RFID Tag”? Is that what is on the spool that came with the TPU from Bambu? If so that’s not the problem because the spool is not in the AMS. TPU is not compatible with the AMS. I’m feeding it externally from my Filament Dryer.
Hmmm… I thought I used the TPU settings. I’m always using PETG so I may have missed something when slicing the model. I was under the impression that once you assigned the desired filament to the model the settings assigned to that filament were used when you slice the model. Is that correct? If that’s not correct, I’m liable to learn something very helpful out here!
I’ve also noticed the high temp plate which is set at 35 is not being followed correctly either. I’m using Wham Bam’s build plate and they have me using the high temp build plate all the time.
Hey… I think I found my problem. When I went to screen shot my Objects screen I found that my object I’m printing was not reflecting the filament number my TPU was using. It was however set to a filament number I had set for PETG!
Thanks so much for pointing me in the correct direction. I’ll try it again in the morning.
I don’t see that page in my windows version. Is it available? I would like to know how to permanently change the PETG HF print nozzle temp to 243degrees. It print 100% better at that temp. However right now I have to wait and babysit until it starts to adjust it. Thanks ahead of time!!
Shaun
