Nozzle Temp is falling back
When starting a print via SD-card the printer does everything as expected until the nozzle heating should start. At this moment the target temp for the print drops down to the actual temp indicated. No error is indicated. Any idea?
Hi,
Does it happen only with the SD card and any print?
If so, use a different SD card to see if it helps.
