Nozzle Temp Malfunction Locking out Printer
Hello. I’ve been using the printer for a few weeks now and I haven’t had any problems. Today I got a nozzle temperature malfunction error 0300–8008 on #7. I did a little troubleshooting and swapped the #7 and #9 hotends and the malfunction moved to #9 to verify that it is the hotend that’s having the problem. I put in a ticket and they already responded and looks like they will send me a replacement under warranty.
Now my problem is the printer will not print anything because it sees a fault in #9. There is nothing loaded and the slot shows empty and there’s not even a spool sitting in the filament slot, but it will not print because of that error. I’ve been searching and I do not see any way to disable number nine so at least the printer can be used while I’m waiting for the replacement. It seems a little silly that a nine color printer would be completely obsolete just because one of the hot ends is having an issue. Has anyone else had this issue?
Did you try if it will work when you remove the nozzle from that slot or unplug the cable from the toolhead of it?
Not sure if it works or throws another error, but could be worth a try.
