I used to be able to click on an object and move it above the bed to a certain height and it would stay there so I could line something else up underneath it but now it just snaps back to the bed. I can’t even insert a number in the “z” column and have it stay in place. What have I inadvertently changed that is making it do that?
Ok I did find a way by moving the socket below the surface and centering it. Then centered the bulb and assembled them both.
Would have to merge it with whatever you want to put under and over it.
Should allow you to move anything anywhere. Wish it weren’t the case.
