Good on you for performing maintenance. I guess it could be a mechanical problem then. Maybe pass your vid on to support.
The only other time i heard something like this was on my printer and it was poop in the rear z lead screw area. I had to buy a one foot long tweezer to get it out.
There’s one thing that might help clarify this discussion. Would it surprise my friends here on this forum to learn that there isn’t truly an X or Y movement in the printer? It might sound odd, but try this experiment:
Turn off the printer so you’re not fighting the stepper motors.
Manually move the print head along a 45-degree angle, from front-right to rear-left, and then repeat from front-left to rear-right.
While doing this, you’ll notice the belts move independently. This shows that each stepper motor, along with its corresponding belt and pulley, controls movement along a 45-degree vector, not along the X and Y axes as you might expect.
Diagnostic trick
If you’re hearing an odd sound or trying to isolate a faulty stepper or pulley, here’s a trick to help identify which belt, pulley, or stepper motor combination is causing the noise:
Create a single-layer test sheet the size of your printer bed. If you don’t know how, here’s a quick guide:
If you want to save time, you can create two smaller objects (half the size), which will work similarly. While it won’t give you a full travel test, it should still help diagnose any noise you’re hearing.
Have u found a solution in the end? My x1c has 1300 hours and noticed that sound similar to yours, started at about 1200 hours. I’ve contacted the support and after seeing my logs they send to me an x axis replacement dude to resistance on the carbon rods. Better than nothing, the sound is improved but unfortunately not the sound for the motivation I’ve written to them. Isn’t bad as yours but definitely isn’t there before. Also I’ve changed the x axis and the belts and when I performed this operation and the gantry was free to move there isn’t any sound like this. So I’m assuming is some pulleys or maybe the head, yesterday I’ve unmount al the cover from the head, also the filament cutter, extruder and nozzle to be sure isn’t they fault and noise still here. I’ve also put some lubricant in the front pulley as the tensioner pulley and also x axis pulley. No luck at all, support just want me to print a test file but this don’t resolve my issue. Maybe the printer just print normal (apart for vfa and ghosting) but if I want this machine to live longer I need to fix this mechanical problem. Like I said before I’ve unmounted the head as the rear panel but I’m not able to locate at 100% the problem, at first to me it seems front pulley fault but yesterday it seems is in the head but don’t have any sense because of the facts I’ve changed the x gantry so it can’t be and the belts doesn’t move in the head. When I have some time I take apart also the right and maybe left panels to see if I’m able to locate the source.
Sorry for not replying earlier. I went via support and basically I got some Superlube 92003 and put a very fine coat on the top side of higher up belt at the back of the machine.
It stopped the noise. Support said that the noise wasn’t causing mechanical issues.
