Having trouble with an off brand filament (Rong Tong) for hueforge prints. The prints tend to stick much more strongly to the textured plate using the generic profile. Have printed with Bambu filaments and profiles until now and the difference is obvious. Absolutely no issues with Bambu, no need for glue or anything. The filament prints fine, its just crazy hard to get it off the build plate, like needing a hammer and chisel to break it loose from the build plate. (kidding but the metaphor is real)
I can tell that the filament tends to inflate/balloon like silk filament when extruding. Not sure if this is contributing to more squish on the build plate, but also not sure if I need to adjust the Z-offset to compensate. If I should have to change the Z-offset, how do I modify the G code to compensate for this filament profile? Or is this a temp thing and need to go lower like 10C-20C and slow down?
No ideas from anyone?
Lol, looks like nobody feels like answering. What type of filament are you using? If it’s PLA, it should stick fine. If it’s something like TPU or PETG or other filaments that require more heat, then go to the Bambu Lab website and find their manual on what build plate to use. You might have to get an engineering plate and then use some glue. I actually found out recently that glue isn’t for getting it to stick better, it’s for getting it unstuck easier, since materials like TPU stick too much to the build plate.
Last thing, just making sure, but check the filament type and make sure it’s the correct temp and speed that the filament requires.
Hope this helps
