Are there any official print profiles for the Original High Flow Nozzle (not the Obsidian) from Bambu Lab for the H2D?
I know I can select the High Flow Nozzle and also change the filament profile to “Direct Drive High Flow,” or manually increase the volumetric speed, but that doesn’t really improve the print speed. I can also manually increase the print speeds under the Speed tab, but I don’t want to risk messing up my prints through trial and error. So, I’m wondering, where are the official profiles?
This has been discussed lots of times. Basically Bambu didn’t do much for Hugh Flow settings and you are on your own. Many people have complained that Bambu released the hf nozzles with little to no profile settings. In Github one of the Bambu Developers responded to a thread where I and others talked about it and he said in one sentence that they will be coming sometime. Support basically tells you to just use sport mode.
That said, if you use them like regular nozzles you still get the better layer adhesion and stronger parts as tested on youtube by a few 3d printing channels.
Wow, that’s so “not Bambu-like.” Especially on a high-end model. I really thought I was just missing something. Normally, you’d expect this to set itself as soon as you change the nozzle and the printer recognizes it.
