Ok, what is it?
I found this in the bottom area of the printer last night and I have not printed anything white in the last few months and everything I did print is not missing a part…
9mm in diameter and 11mm tall
Any idea if this is a part of the printer?
Bill
I fed your question and the photo to ChatGPT. ChatGPT asks for a photo showing the other end of this piece. Also what printer do you use? What area exactly did you find it?
I filed it under the H2C Series section, so H2C :grin:
Other end is smooth with no marks or patterns. Laying on the floor of the compartment below the build plate.
Bill
ChatGPT can’t make a positive identification :slight_smile: . Here’s what it says.
[begin of ChatGPT output]
Since you have a Bambu Lab H2C, and the piece was found on the floor of the chamber beneath the build plate, I would focus on components associated with the Z-axis mechanism, build plate supports, and shipping hardware.
Looking at your photo, a few details are interesting:
  • Dimensions: 9 mm diameter × 11 mm tall.
  • One end: Completely smooth and flat.
  • Other end: A recessed geometric pattern resembling a cross.
  • Exterior: Smooth cylindrical walls, with no visible threads or attachment features.
My current suspicion
The piece could be a plastic spacer, protective cap, or shipping-related component.
The recessed pattern could also be a manufacturing feature rather than a functional connection.
However, I haven’t identified a matching H2C component, so I wouldn’t conclude that anything has fallen off the printer.
What I would check
With the printer powered off, inspect the following areas:
  1. Underneath the build plate: Look for any missing plastic spacers or caps around the platform supports.
  2. Z-axis lead screws: Check whether any white plastic components appear to be missing.
  3. Bottom of the chamber: Look around the edges and corners for additional pieces or evidence that something has come loose.
One important question
How long have you owned the H2C?
I’m asking because if it’s relatively new, a leftover shipping or assembly component becomes a more plausible explanation.
If you’ve been printing successfully for months and this piece appeared only recently, I’d be more interested in determining whether it came from a moving mechanism.
At this point, I can’t confirm that it’s a printer part. I would keep the piece and avoid disassembling anything until we have a stronger identification.
[end of ChatGPT output]
It looks like a partially printed white object.
The inner structure looks like a grid infill.
I can’t see any layer lines, but it feels like a part that was partially printed.
If it’s not a printed part, I would not have a clue, what that could be.
(post deleted by author)
Someone secretly used your printer? :grin:
It looks printed with grid infill, so its probably just some trash. Something got swept off the plate once upon a time
Definitely printed grid infill. Lesson to learn: Do not use grid infill :joy:
Rectangular is just as fast but does not incurr speed bumps at the crossings.
Machine has about 600 hours on it since early August when I received it new. The part in question appeared last night during a print job. I have found no other odd pieces.
The machine runs normally and quietly.
Part has no hole, so it is not what I would call a spacer.
It certainly had all the hallmarks of a piece from a print job.
Digging deeply in the WayBack machine I found a video of a failed print. One of the first prints I made with the machine. I had forgotten printing parts in white and must have used it because it was loaded in the AMS from one other very different project.
Makes me wonder where it was hiding all this time, it’s not like there is no vibration when the machine is running…
Sorry for the time wasted, but decades of auto repair has made me sensitive to mysterious “extra” pieces, which goes hand in hand with “you drop a nut/washer/whatever”, you figure out where it went. A guy I worked with lost a nut and never bothered to look and nuked a early 80’s 930 Turbo Porsche engine.
Bill
Nope, but the cats seem to like sitting on top of it because it is warm, however they are not too enthused about the “massage” feature…
Bill
Ok, it is clear now, cats throw it inside to trick you it is broken, so you can leave them alone :rofl: . And stop annoying them with vibrations and strange noises.
