in one printjob I use ‘Add pause’ to stop printing at layer 105 for inserting a nut.
So far no problem. The printer is printing the model and stops at layer 105 as expected.
The buildplate lowers a littlebit and I try to insert the nut.
My problem now the buildplate is still too high so I don’t have enough space to easily insert the nut.
Is it possible to get the buildplate to a much lower position if it stops at layer 105?
It would be best if I could determine how far down the buildplate should go.
A Pause on my X1C stops the print and moves the nozzle over the purge chute, so I’ve never had a problem getting access to the model on the bed. Maybe you are working on the rear edge?
I also add a pause to change filament at a layer (no AMS). The first time I tried that I had a problem because the X1 screen only offered Resume and Cancel choices, and I could not get to other screens. I found that I could use the print head controls in Studio or Handy to load and unload the filament, purge, etc. This also works to move the bed. The bed will return to the correct height when the print is resumed.
Simply lower it more as required using the on-screen controls, it’ll resume correctly although potentially with a little more filament ooze as it takes longer to bring the bed back up and the head is already in place and at temp while it’s moving up.
If I press pause on the printer, I can manually move the print head and the printer plate through the printer display control to any position I want. If I then press start again, it just starts printing again.
Can also be used to clean the sputum or brush the nozzle during a paused print. Especially when the poops no longer separate properly from the nozzle and the printer constantly stops because of a spaghetti warning…
As @JonRaymond proposed, I changed the standard GCode for pause at height since for mee it seems to be most comfortable solution.
I used this G-Code (from perplexity.ai):
G91 ; Relative positioning
G1 Z100 F1000 ; Move Z axis down by 100mm (10cm) at 1000mm/min
G90 ; Absolute positioning
M400 U1
This causes the buildplate to move 100mm down. So far no problem.
But if I hit ‘continue’ then the filament does not stick to the last layer. The printhead prints in the air until the end. I tried this several times.
BTW: If I move the printhead down using the controls on the X1C display (as @Kilrah proposed) to move the buildplate down and then continue the print then it works without any problem. But its not so comfortable compared to a solution by G-code.
@duane777, thanks for reply, but I am not that familiar with G-Code. I just took that what the AI gave me.
So no, I did not try anything else what I wrote in my previous post.
What please should I try?
I am looking for the exact thing but opposite. i need to raise the z height after pausing so i can add magnets. the bar is always so lower i can barely get my fingers under.
I have an A1 so i need to return back.
i added exactly the same code as that works not the opposite as i would have guessed( im a smart cookie) plus is plus and minus is minus. my problem now that i am looking at is my extruder is not advancing could be my filament . but any one else have that issue?
Got the same issue. However, i found out you can just move the printbed down during a pause via the menu on the printer. If you move it down, then press resume, it moves back to the original position and also resumes extruding.
M400 U1
G1 Z-100 F1000 ; Move Z axis UP by 100mm (10cm) at 1000mm/min
I just added this code to my “Pause G-Code” section of my machine and my print paused and lowered the bed as hoped, however once I started it again it is no longer extruding. It’s running the nozzle across the print, following all the correct lines however no filament’s coming out.
To check if the nozzle somehow became clogged I paused again (allowed the bed to drop) and, using the touch screen, told it to extrude a little filament and sure enough filament came out the nozzle. So I then resumed the print again, but still no extrusion!
I’ve looked online and see else where people are suggesting adding an M83 command to the end of the Print G-Code to get the extrusion to work. Is this necessary and if so any idea why it’s not mentioned in this discussion?
BTW I currently have my print paused at the layer after the pause (after spending the better part of an hour gluing in 64 magnets). I really don’t want to abandon this print (and those 64 magnets). Is there any way I can activate the M83 code and resume printing, or even better, restart the current layer?
I was having the issue many have mentioned where after resuming printing there is no extruding. Adding an M83 to the end was the fix. I can’t find official documentational of this code but Ai said M83 was relative extrude mode and that something replated to the pause might be putting it in to absolute extrude mode whish leads to this no extrude issue.
Here is the working code just put this into the printer Setting / Pause -G-Code box:
G91 ; relative positioning
G0 Z150 F3600 ; move bed down 150mm (nozzle up, away from part)
M400 U1 ;pause for user
G0 Z-150 F3600 ; return bed up by 150mm to the prior height
G90 ; absolute positioning
M83 ; Set extruder to relative (important to resume correctly)
