One roll of filament not adhering
Still kinda new to 3d printing… I have a Bambu P1S with AMS. I’m using Overature PLA filament and am having an issue with one roll not adhering to the build plate. It had been working alright but I noticed some stringiness so I put it in my Creality drier at 60C for 6 hours and now its not adhering at all once I get to my third of fourth layer. I scrubbed my build plate with dawn dish soap and rinsed with hot water and it still won’t stick. All my other roles that I currently have in my AMS, also Overature PLA, adhere just fine. What could be the issue with this one roll?
Thanks
Overture’s recommended setting for drying is 50 C.
There’s a chance you may have degraded the filament by drying it at the higher temp.
Remember, all drying can degrade filaments to an extent. More heat, longer dry times, multiple cycles can all increase that degredation.
60C is far too high of a temperature for drying standard PLA. The roll is cooked, unfortunately.
I have a Creality Space Pi dryer (2 roll version). The preset is 50 for PLA. Their website says it’s 55 but documentation is a lie; the truth is the behaviour of the machine. :slight_smile:
I wonder if OP had basically pre-annealed the material?
@user_2294216768 one thing you could try is bumping your nozzle temperature up…that may be enough to get it to stick to the plate and itself.
I’d go up in 5 degree increments to see if anything changes, probably no higer than 20 degrees overall.
Maybe try with some glue - I like 3DLAC spray glue. But there are several glue products on the market.
