As currently implemented, this feature would be more accurately described as “Only one wall on the highest surface”. The reason being that all top surfaces that are not the tallest currently do not meet the criteria for “Only one wall on top surfaces”.
I’ll show 3 examples.
First image shows 3 cubes all the same height (6mm).
All 3 cube top surfaces meet the criteria of “Only one wall on top surfaces”. But the top of the base does not (even though the Color Scheme legend shows it as a top surface.
Below, the cube heights are 6, 7 and 8mm (left to right). Only the 8mm tall cube meets the criteria for “Only one wall on top surfaces”.
Below, the pyramid is the tallest part at 8mm. The 6 and 7mm cubes and the base do not meet the criteria for “Only one wall on top surfaces”.
