Open API - at least send gcode and check status
I would really like to add to this request. I’ve recently come from a klipper converted Ender 3 S1 Plus and previously Octoprint (with Ender 3 and Ender 3 S1). I have started using my HomeAssistant instance to monitor my P1S as it is more reliable than the Bambu Handy app.
I’d like to see an API that will work with OctoPrint or similar that supports basic functionality inc file management. I’d even add another box if it gave the functionality required.
I get that it’s good for beginners but some of the most basic functionality against Klipper / Octoprint / Duet is really missing for those of us moving across from these types of printers.
The actual printer thus far is excellent. The user interface is, imo, lacking.
That’s great @iChris . How is it going your beta? I’d like to test it. Thanks!
Interested in API information
This would be amazing. There is so much potential here and if something like this could be rolled into HomeAssistant as an addon it would rock! This would go some way to adding back webui stuff I am missing having moved over from Klipper.
I don’t see how this is relevant and appears to be a logical fallacy to justify deceptive business practices (at best).
You can enable LAN control and also only deliver firmware updates via cloud.
Just say you want to see what every printer is making and you’ll save yourself from spending so much time pretending to care on the forum.
You mean making the existing API accessible to customers won’t be happening soon. It is all done by API already, the api exists.
If developers had access to the APIs they could develop an appt that would allow monitoring & control of the Printers via Home Apps (Home Kit / Google Home) - I’d like that!
Please @BambuLab share / open up the APIs used by your printers!
I would love if I could just get the print info. I want to get time, image, filament type and amount. If we had that solution at our MakerSpace the Director would probably buy 5 more machines from them. Maybe even more because I think our members would use the printers way more if we had these style printers. We have one machine now but being that it’s a manual process to check and gather how much filament, time each print takes is really next to impossible. We are all volunteers at our space and that’s a lot to ask people to do.
Welcome to the forum.
There are both open source and commercial ways of doing this.
Check out this thread for open source Bambu farm management.
Or check out https://www.3dprinteros.com/ for a commercial management system.
Hello, I’m a prospective customer for a 3D printer. I’m by no means anyone special, but I think it’s helpful that Bambu know where we’re coming from, and why they’re missing some (at least one) potential sale(s). I’ve never touched a Bambu printer, but I’ve seen a few in person.
Bambu printers are high quality, and well liked in the community. They are consistently well-done, quality products in a sea of printers where corners are cut in the name of a few cents.
Everyone knows this. So why isn’t the Bambu labs the next Ender (yet)? In my opinion, Ender’s edge comes in the fact that there is not a single proprietary part / software on a stock Ender 3, or 5. Because of this, there are hundreds of hardware mods for the Ender, tens of thousands of software contributions to the firmware, and has an entire ecosystem of makers working on additions, improvements, and mods for free. This, in my humble opinion, is the biggest separation between the two products.
An open API interface could be a small but important start towards garnering this sort of community. We aren’t looking for pristine libraries that are in every programming language imaginable. We’re looking for some simple documentation of API calls that we could write code around, and maybe an example of code performing a few of these calls.
I’ve seen the open source bambu-farm project, and the API is there, and able to be called by 3rd parties, we just need the docs. :slight_smile: I know there is a community of tinkerers and developers out there that are chomping at the bit to make free software for Bambu printers, it’s evident purely from the attempts that have been made thus far to reverse-engineer the protocols.
I urge those at Bambu labs to at lest consider making the API spec open, this is low hanging fruit in terms of methods to increase both community and reputation.
Thanks for taking the time to read this.
My team from odysse developed a plugin / API where you can use to upload STL files, customize your print settings then the API will handle the calculation for cost, turn around time and final dimension.
Hi I’m moving away from Anycubic specifically because of their closed API and I was about to buy a P1S today until I discovered this thread.
You just lost a customer here because of this missing feature, I registered just to tell you that :slight_smile:
What’s the problem? e.g. the Home Assistant integration has all you could think of and it works perfectly…
Based on this thread I thought @SirWill said they aren’t interested in officially supporting the API?
The bambu-farm repo says bambu recently blocked mqtt access unless your printer is lan-only mode too.
Does the home assistant integration support remote printing or sending gcode?
I see various issues about cloud vs lan features and couldn’t work out what is supported
(I was the dev of the anycubic HA integration until they blocked us out)
