Operating hours
Good morning everyone,
I am actually wondering if there is a possiblity to see the total printing hours of the machine on the P1S.
Looking forward to read you soon, I wish you a good day.
Giving this a bump. I’m also interested in this - lifetime print hours. It was available on the Kipper/Mainsail days and I miss it!
Already asked a few times, just use the search bar:
Well, if you read the tittle it’s about the P1S and not X1C.
Thank you for your precious answer.
Sry, overread that.
But seems it is getting logged, since the P series are based on the X series.
I know that the X1C log the operating hours but I couldnt find information that it is available to the P1P and P1S too. Did you find the function somewhere on a P1P/S? On a X1C its on the display under “General → Device Info”
My solution with Home Assistant just reports the hours when the printers state is running. Its kind of a workaround but not really an ideal solution as it would come from Bambulab directly.
There has been talk of adding “Printing Hours” in the Xtouch display community. I’m assuming it will monitor and calculate with a similar method as you do.
Just an FYI. Hours for the P1S and P1P afre now available since the last update. Scroll down to device, settings and you will see it.
My hours are way off, one of my P1Ps shows 348 hours, the other shows 323…I know there is over 800 hours on them…my best guess is 800-1000 each. Same with my P1S, it shows 346. My best guess there was a update that started counting from there forward since they are all around the same hours and all get used the same amount. The P1Ps are 9 months old and the P1S is just under 6.
Yup mine is reporting 0 hours when I’ve done at least 50ish
Maybe the counter only began after the firmware update, or perhaps you have to wait for them to calculate via cloud
How do you read number of hours your machine has?
Interesting. Can you guide me to read number of hours of my machine? I don’t see this anywhere in the menues.
Have you updated to the latest firmware release? The hours feature on the P series is relatively new.
I keep meaning to watch the hours more closely. Does the counter display actual printing time or all the time the printer is powered up?
On the third tab - navigate to where it says Device: Bambu Labs P1S. Then hit OK on that. Then the next status page will show the Printing time.
I can verify on that the X series is actual printing hours. The P series I haven’t watched close enough to make that call.
