Are there any methods by which H-series Bambu printers can be operated using split phase US 240v power? An upgrade kit for this would be the ideal solution. Thanks in advance.
… why? Our split phase is 2x 120v. Just plug it in to the 120v leg.
Unfortunately there is no official path for doing this - I pursued it for my H2C and gave up. Requires a new power supply, new AP board (if I recall correctly) and not sure what else. Bambu wasn’t too keen on supporting it when I asked, but maybe if you tell them you’ve moved to a place with only 220 power and you can’t run your printer any other way they would help.
Spread the load over L1 and L2, if possible.
Are you having issues that would require this? A split phase system is designed to handle asymmetric loads just fine.
I would guess the bed heater is the main issue, as that is directly powered from the power grid.
I didn’t check the PSU, but nowadays most of those allow for a broad input voltage of 110V-240V @ 50Hz-60Hz.
I would guess that the AP-board would need a replacement because it’s probably checking the input power for safety reasons. In other words, don’t allow the bed heater to function if the voltage is incorrect.
I’m sorry, but that just isn’t a thing in general - 220 single phase definitionally uses both legs equally, but you seem to be saying you actually want the printer to run on 120+120 - that’s also not a thing, I struggle to think of any discrete consumer electronic devices that use two power inputs.
If you’re trying to limit circuit loading, the printer has a low power option that draws less peak current.
I own a couple of pieces of “Pro-sumer” stationary shop equipment that have the option of either wiring to standard 120v house wiring or 240v split phase, (120v x 2) circuits. Those devices split loads between L1 and L2, thereby reducing draw on either leg. Distributing heating loads between the legs would be the likely design feature of a printer that would accommodate US 240v.
