Organising SD card in Bambu XC1
I have so many models and version on my SD cards, that it is difficult to find a specific item to select for print.
Is it possible to update the software with a possibility to have a folder structure like any computer or smart phone? That would be much easier. Now it is often faster to upload an item again from the slicer than searching for the previous version on the SD card. I did make a few folders on my computer but these are not shown, just the contents of the folders is visible without any hierarchy except last uploaded is first visible.
I just know Bamby can do better.
thanks.
you can do it yourself through your computer, then place the card back in the printer slot. That’s what I did, and many others as well.
Of course, that’s the first thing I tried, but I can seen the folder structure on the computer, but it’s not visible on the printer display, only what is in the folders.
Check existing folders structure and properties, copy or replicate them, then rename as needed. Then copy your print files where you want them to be.
Hi @drakko !
It seems you have been able to implement the folder structure on a bambu card… Could you please share a little bit more details about it, as this would be of great help to my team ? I tried to simply duplicate the cache folder on the sd card and rename it but the P1S won’t see it… Could you share more details about your process ? Many thanks !
Is there anyone that can explain how to organize files on the SD card?
