P1 chamber light thoughts
Let’s face it, our light isn’t the best out of the box.
I removed the front cover to get a bit better light and was stunned by the insides.
Those SMD LED’s face upwards onto an angled reflector of white colour…
Don’t know how efficient this is other than diffusing the light better for the camera…
Anyway…
I tried some of the ‘dedicated’ light strips from a certain Chinese shopping platform…
All claiming to be happy with those 150mA the P1 light port allows for - all rather crappy in terms of light output.
Those strips are just not meant for the purpose of providing a flat angle of light - they spread too far.
Even these COB strips failed to impress me and so I gave up weeks ago.
Now I had a weird backlight strip from a TV - with 7.2V diodes on it…
Did not trust this cheap LED tester but my multimeter confirmed the readings.
It wasn’t the 7.2V that impressed me though, it was the simple design of the strip.
20 of those diodes in series and at full brightness (compared to full white on the TV) running on 84.5V.
White LED’s usually require at least 3.2V in the ultra bright classes.
But there are some reaching full level already around 2.2V and that at just 20 to 22mA.
5V is the supply for the LED port, 150mA our max.
2 LED’s in series gets us close enough to 5V without risking those LED’s burning out, but of course an added resistor is always good.
Means we have 22mA used so far, make it 25 in case those low current LED’s are unavailable.
With that we can put 6 of these pairs in parallel.
7 or 8 if we can get away with lightly less than 100% brightness.
So at least 12 very bright LED’s…
That would provide a meaningful length for a lightbar but also comes with the problem of beam angles.
Usually these LED’s are clear and with beam angles between 25 and 52 degrees.
Unless we sand the top a bit we still need some sort of diffusor to prevent glare.
Still possible…
Then I thought about what the actual issue here is…
150mA is the issue…
On 5V that means 750mW - any half decent flashlight these days already comes with 2W LOL
So we need a booster…
Not a problem in the world to find 5V LED lights - strips, COB light, USB sticks, whatever you can think about.
Including desk lamps, video lights and more…
Everyone has some old USB charger around that is of no good use with USB-C everywhere…
Even a lame 2A provides 10W !!
How to connect it to the internal light though ?
E-switch Mosfet Module of course.
3 to 12V on the input for the signal and next to no consumption.
On the output 3 to 40V with up to 22A…
More than enough for a little LED strip…
Control for the switch is wired to the original LED output.
And the switching part goes between power supply and LED strip…
Chamber light off, strip off, easy and while off you only have to worry about the standby power the USB charger might have…
Use a LED strip with app control or with IR remote and you can even change brightness and colour.
At this stage of my thought process I really started to wonder why a solution isn’t available from China already.
No problem to use a kapton film strip to get power through the lid and from there to the strip.
Without that one could even run some thin dual core wire through the poop chute to get light under the hood.
Has really no one tried this yet ?
The light problem has been solved many times over. More times than I care to list here. The picture below is of my X1 cabinet. The dimmer isn’t even turned up all the way. And to the nay sayers about affecting the Lidar, I say preposterous. The Lidar creates its own shadow for reading since the light is from above. The extra light turns the camera into a great accessory for printing.
Looking nice indeed but does the X1 come with the same 150mA limit on the LED port?
With more than 150mA I see no problem to get decent light into my P1…
BIQU has a nice “Panda Lux LED” upgrade kit. You just snap it on the frame with magnets and connect it to the existing connector.
Only problem is dat max output seems to be 30mW on that connector, so I would not be able to simultaneously use the already installed LED (while thet provide an extention board with it).
But I’m going to use the internal USB-port to solve this problem, which has a max output of 150mW on the P1S.
can u still turn on and off the light with the printer?
Sff7113d9f45c468c8a5a72184840e3acW.jpg_120x120
You can find these little sticks on AliExpress by searching USB light. The link won’t parse correctly here, but they’re not difficult to find.
Put one in the USB port. Will provide enough light. I ran one for awhile (month or two) before I decided to go with a riser.
The bigger ones run a little hot. The three light is just right. Will turn off with the printer and back on when you turn on the printer. Downside is you can’t just turn it off.
Easy and cheap. BTT’s solution is ok, not that bright.
If you want to easily get more light in your chamber without heavy modding… Check this out:
Here is a video of the effectiveness…
Halfway through the print I turned on the light.
I thought LED light strips and printed parts to mount them is overkill. Home Depot sells thin square LED lights over a range of sizes. I put a 7.5” unit on the glass and then build four 1 1/8” risers for the AMS. Works well. Doesn’t heat the glass and minimal mods. Also easy to get into the unit for service.
Sound kind of like what I am looking to do. I’m not finding a just USB/or Outlet plug in square led light. Did you end up wiring up one of the flush mounts to some kind of switch?
I have a power switch behind my printer. Basically a switched set of outlets. I wired the 110v led unit to a power cord and plugged it into the power strip. The printer is also plugged into that power strip.
Here’s a really stupid thought >
The big switch on the back of the printer is useless if we dare to use a powerboard or wall outlet with a switch.
Makes no difference at all to the printer at which stage the power is lost.
Not for the faint of heart free of soldering skills and unaffected by common sense:
A cheap LED nightlight usually comes from China and only has a capacitor, resistor and LED in it.
Those with a light sensor an added sensor/green LED and transistor.
Means that we could abuse this to route the light detecting part to our interior light while replacing the capacitor allows for higher current and more powerful LED or LED strip.
Considering how simple it is and how many people keep asking for a solution and wonder why there is no such solution ready to go from the usual Chinese market places…
But then again, there is lazy people lime myself who just combine the unthinkable to get what is needed LOL.
Like combining a $5 thermostat thingy from Ebay for ‘fridge and heating applications’ to switch o a LED light.
Printer prints means here the bed is on, means whatever air comes out of the exhaust fan is warmer - the thermostat turns the light on and once the print is done and all cooled own it turns off again.
Keep in mind though I don’t do much the usual way LOL
Would something like this work? Amazon.com
Not 100% sure where to mount it. I just got my P1S today. It’s on it second print
this is pretty genius move IMO
I added the BiQu light bar.
HUGE improvement!
$12.99 on Amazon & magnetic mounts & plugs into the existing plug. Just remove the wire from the crappy OEM one & plug it in.
It’s NOT as good as a complete led rope light around the top, like I see folks doing, but it’s quick, easy & cheap.
Bought this strip to replace the stock light. Works fine.
1005005873305547.html
New here to the forum. Did not care for the chamber light right out of the box. Bought a 10” ring LED ring light from Amazon. $12. Used 4 pieces of Alien tape to stick it to the outside of top glass, centered. Runs of a USB power cube. Greatly improves performance!
Looks clean too. If you have an AMS, print the risers! This way you have room for the light, and can vent the chamber.
Be Good!
Really any 5v usb light should do. On our second P1S I didn’t bother even doing riser for lights. Just threw in one of the USB light bars I mentioned earlier. Plenty of light and far less hassle.
The first P1S I purchased the cobb light from BBL (the overpriced one) and printed a riser for the AMS that would incorporate the lights. I have a tap that runs off the printer (2-24v 4pin) that is switched I run those lights off of. Been like that for years.
Thing is I’ve found I just don’t use them that much. Checking a problem for a minute or two is about all I run them for. You may want to keep that in mind. The little USB light does the trick. Far brighter than the BiQu light, even the newest RGB one (yes I’m a sucker).
Where did you add this? I was thinking about this too, but i’ve checked that it might be in way of the toolhead?
