P1P Failed to print model using ABS
Using eSUN’s ABS material to print the model, there are many layers, I don 't know what went wrong?
i have the exact same filament too. the problem could be that the printer is not enclosed, and therefore ABS and ASA experience lots of warping. i don’t know your setup. also i had problems with it extruding too much. try to set the volumetric flow limit eg to 6-8mm3/s.
i have Orca Slicer and calibrated all my filaments for temperature, flowrate and pressure advance, do that too.
rise the temp to 250 degree and try 0.985 flowrate. pressure advance was 0.024 for me for ABS+ and for PETG 0.036
thank you! I have time to try your method!
how did it turn out? i’m curious :slight_smile:
