P1P filament stuck
I have an AMS and I’ve had to tinker around a lot with it. The AMS sits on
Top of the printer. My filament keeps catching in the tubing. The tubing keeps getting smooshed by the extruder. I am sure there is a simple fix. Help?
Including pictures and detailed information about the print speeds, filament type and settings used will help get the appropriate solutions.
Hmmm what happend to the cable chain assembly where the cable normally runs in and the PTFE tubing is clipped on to?
Hello,
it looks like the PTFE-Tube goes straigt down from your AMS into the Printer and when the Printhead moves back, the Tube gets stuck.
On the X1, X1C and P1S the PTFE-Tube runs along a cable chain and at the Backpanel out of the Printer.
If you can reroute the Tube, it might solve the problem.
“Hmmm what happend to the cable chain assembly where the cable normally runs in and the PTFE tubing is clipped on to?”
Great question, indeed…
Something is very odd in those pics…
If you look at pictures, it seems the P1P is not stock equipped with a cable chain.
