P1P not cycling through auto bed level
Hi, first time issue that I have had that I genuinely not sure how to fix.
I have 2 P1Ps the older has now stopped cycling through start up auto bed level. It’s gets about half way through then cancels the job. The other p1p is working fine.
I have ran this quite a few times and still run into same error.
I have cleaned and greased the rods, it is extruding fine. I have manually moved the head to the area that it stops auto levelling.
I swapped sides with textured plate.
I’m not sure if the issue is the belt or the software.
Any help would be greatly appreciated
Many thanks
Hello @Bell ,
Welcome to the forum.
Sorry to read about the issue.
Is there any error message or code?
Try swapping the SD cards between the printers and see if the problem follows the card. Failing SD cards can do weird things.
It’s strange no error code just goes from auto bed level to job cancelled.
Brill thanks, have another one ordered, hopefully it’s a easy fix :slightly_smiling_face:
