P1P to P1S upgrade - no P1S Processes available
Upgraded P1P to P1S and finally got the printer to accept sync of AMS to the P1S printer profile (thanks to all who made suggestions in that thread).
However, now all that is working my attention turns to processes.
If I select the P1S printer there are NO Bambu-supplied (@BBL P1S) processes and none of my P1P custom processes shows either.
All that is available is X1C processes (0.2mm Standard @BBL X1C for example).
Going to Printer selection and removing the P1P and adding the P1S did not cause BS (or Orca) to download standard P1S processes.
Also, although I have removed the P1P from the Printers selector, I still have a P1P machine profile.
Indeed I can select that, see all my custom processes for the P1P and use them!
When I try to print them of course, I get a warning about the gcode because it is slices with the P1P machine profile but I am sending to what is now seen as a P1S (since I installed 1.07 firmware and set the upgrade flag).
Surely there should be “@BBL P1S” processes available?
Anyone have this problem and fixed it?
Nope, there are no separate processes for the P1S. Mainly because the P1S is basically the same printer as the X1C just without all the fancy bells & whistles like the lidar etc.
The processes are identical so no need to add separate ones for the P1S you just use the standard X1C ones.
Although I do think Bambu Lab should change this to avoid any confusion.
Even just putting them as “0.20mm Standard @BBL X1C/P1S” or similiar would solve the issue.
Thank you so much for the clarification Sir!
