Hi All
My P1S keeps going to Pause !
What the F*** is wrong with it its a week old …
Hi All
Exchange the SD-Card. May be damaged…
Sounds like it could be a bunch of different things as there are lots of posts from other users having a similar issue on these forums and reddit. Is there a specific error message you’re getting?
Here a few examples of how other people fixed their pausing issue.
One users fix: “I solved the same Problem 2 days ago. My Magnet Cover at the Printhead was not perfect in Place because the cable was between the magnets. After attaching the cover in the right spot it works perfect again.”
Another user says it was pausing on them because it wouldn’t keep the temp properly and it ended up being due to the silicone sleeve missing
A third user says: “I added a pause at layer a few projects ago and that was the cause
Let me ask my Magic crystal ball with all the useful information you gave us.
Found the problem , Faulty SD card
Issue:
The printer kept pausing at the exact same layer every time.
Troubleshooting Steps Taken:
Tried a new SD card
Regenerated a fresh G-code file
Tested multiple prints
The issue still continued.
Diagnosis:
After checking further, I noticed the hot end was not maintaining stable temperature. This caused the printer to trigger a temperature safety pause at the same layer.
Solution
I replaced the hot end with a new one, and the printer is now running smoothly without any pauses.
the silicone sleeve is missing on mine is missing but it has been for 3 months and now when i try to use it it keeps pausing and now the speed is really slow on the x and y axis and after 2 pauses it started smoking near the extruder
