I was getting clogs in my extruder from the filament bulging by the extruder gear and being unable to move. So I had to take the extruder apart several times. I know about heat creep now and keep the lid and door open. I haven’t had any more clogs, but my p1s started printing like this and I haven’t been able to figure out why.
- I’ve tried 3 different hot ends to rule out partial clogs
- I disassembled the extruder to make sure it’s working and filament passes though easily.
- I switched out the extruder gear and made sure it doesn’t have any residue/filament on the teeth that pull the filament, none of the other gear teeth are worn down
- factory reset → calibrate → bed level
- manual tension the x/y belts and cleaned the rods → calibrate → level
- tried different z offsets in the machine start code
- removed AMS and been using external spool directly feed into print head, no tubes
- tried different filaments
- increased bed/nozzle temps (helped a little)
- increased flow ratio (helped a little)
I’m using a 0.6 nozzle, Inland PLA filament, and the gold textured PEI plate
Increasing bed temp helped with adhesion problems I was having, I think from opening lid/door. Increasing nozzle/temp and flow ratio helped reduce the gaps between the lines in the squares of the first print. In a lot of these first layer tests prints the bo9ttom right corner looks good, then it starts breaking up.
Anyone know what could cause those gaps between the lines? This machine was printing perfect first layers last week. I’m not sure what else I can do.
