P1S Printhead crashes during pre-running test
I am a beginner with this printer. I can print samples from the micro sd and they are very good. But as soon as I try my own designs, max 50x50x50mm during the pre setup, the print head crushes into the door an sides, as if it tries to cover a bigger area.
I use Tinker Cad to create designs, exporting stl files. Than import to Studio. Due to network problem I export gcode file, copy it to the SD card and insert into the printer. And then the crashes happen. What needs to be done? is there a setting that limits the head movements?
Also, is there anybody that can locally help in Western Australia?
make sure you slice using the correct printer selected on the slicer
Thanks a lot, Warmup. I found the problem.While the device section showed the P1S printer, in the slicing parameters it was set to A1 printer. Now all prints fine.
