The factory rear spool holder on my P1S lets the spool ride right up against the belt tensioner housing. Mine would rub and catch on it — worse with wide spools — and I didn’t trust it not to snag mid-print.
So I built a replacement. A printed plate bolts to the back panel, and the spool rides on a barrel spinning on two 608 bearings over an M8 bolt. There’s a flange on the barrel that acts as a positive stop, so the spool physically can’t walk over into the housing anymore.
The knob end is a two-nut jam lock with a printed wave brake. You set the drag once (a shim sets it — thicker shim, softer brake) so the spool turns with the barrel instead of free-spinning and throwing a loop of filament.
Printed and running on my P1S. The X1 / X1C / X1E / P1P use the same factory rear mount, so it should fit those too — untested, mine’s the P1S.
Free on MakerWorld if yours rubs too: P1S Spool Holder-Fixes Spool Rubbing - Free 3D Print Model - MakerWorld
Designed by a builder, not a CAD man — measurements and shop testing are mine. Happy to answer questions.
