P1S just decided halfway through the print, that it was done. Print cancelled. No error code, nothing. Just stopped in the middle of the layer. Did not return to home, or lower the plate. The nozzle stopped mid layer on the object, and remained attached as the plate cooled.
Turned it off, turned it on again. Nothing. Ran a calibration it all seems fine. It just decided to nope out over half way through the 10 hour print.
Thanks! I see that this is an ongoing issue. I’ve swapped out the card for a new SD card I bought recently for my camera. We will see if it happens again. I’ll be keeping an eye on this issue and hope it gets fixed in an upcoming firmware update.
I had this happen a couple of weeks ago. I had to power down the printer to get it to respond. I sliced the file again and sent it to the printer. It printed with no issues and has not happened since. I did buy some new SD cards in case that is the problem.
I had roughly the same problem. An A1 with 2 AMS-HT units. After drying the filament, I started the print (6 hours). After a few hours, it stopped the print because it wanted to dry the filament again (!?), but it couldn’t do this because the filament was still in the tube. I restarted the print and again, after slightly longer than before, it stopped because it wanted to dry the filament again. After that, I turned everything off and back on, and then the print was successful.
