P2S won’t feed PEBA - I have tried everything, Dried the Sainsmart 90A for 2 days, changed the nozzle to a .6, Cut the filament at a sharp angle, preheated the nozzle and manually directly fed from the top and it just won’t feed. It grabs and lowers when I push the button to feed but stops at the head. Seems like I have clogged 2 heads a .4 and .6. I just couldn’t print with PLA in those heads. I swapped to a new .4 and the PLA loaded np. Also TPU feeds np I made a airless basketball that didn’t bounce very well. Please give me some suggestions.
I think you’re trying to say the filament gets past the feed gear but won’t make it into the hotend?
If there’s a stub of other filament already in the hotend, the PEBA has to push it through, for flexible filaments that can be tough.
I’d take the toolhead cover off while doing this, set the temperature a bit higher, and try loading and see if the PEBA is able to push the other filament through the hotend.
If it still struggles you may need to heat up the nozzle and push the stub through using a different filament, then retracting that filament rather than cutting and then try loading the PEBA.
I would suspect this is what it is, but they said TPU feeds no problem. Although their TPU might be a harder variant like 95A or 65D.
This is the reason the machine prompts you to do a cold pull before printing tpu.
Cold pull cleared the clog and then I manually fed the PEBA and let it spool out on the plate. Then started the print. It’s working GREAT thank you for the help.
Fingers are crossed on the basketball ![]()
