P3C hotend
https://eu.store.bambulab.com/it/products/bambu-hotend-h3c
Is this hotend the same for p3c?
I can’t find one specific for p3c on eu store.
Yes, just keep in mind that that is only the hot end and not the entire tool head. If you’re trying to add an additional tool head this will not work. If you’re just changing out to a different size this will
I added two more toolhead and I would like to change the 2,85mm hotend, it should work fine I assume. Thanks!
Be aware that the 2.85mm tool not only differs in the hotend but also in the tool head itself from the standard 1.75 tool.
In other words: it does not work to swap on a standard tool the standard 1.75mm hotend with a 2.85mm hotend.
Correct me if I’m wrong.
I believe you’re right, from the picture toolheads are different and so maybe also hotends are not compatible.
You are correct. The tools are different.
Hotends are the same, you can install a 0,4,0.6 or 0.8mm to your 2.85mm printhead and print 2.85mm TPU with them but you cannot use 1.75mm filament in a 2.85mm printhead
