Was pleasantly surprised.
Brings up another question I have not found an answer to, so far.
How do you add an aftermarket plate to the Plate options dropdown?
They’ve got the Cool Tack added already.
I don’t know that you can. . I just use the closest Bambu plate
I do not believe it is possible to do this in a meaningful way. The reason is because the plate information is distributed across other profiles, for example the filament profile will have an entry for each plate type. So adding the the plate to that pulldown won’t do anything useful, you’d need to modify the code to support new entries in those other profiles as well. Sorry about that, it would be handy to be able to add plates easily!
