Panda Revo Hotend
I’m looking at getting the Panda rivo hot end and have a few questions for other people that have it already.
I see the revo not not come in a 0.2 mm nozzle like the stock bambu nozzles How does a 0.25 compare and is they’re a way to tell the bambu slicer that you’re using a 0.25?
I also assume that you take the fan off of the stock hot and put it on the revo?
And lastly, can I get some nozzle recommendations?
Regular vs ObXidian vs ObXidian high flow. I do print lots of different materials.
Thanks
I have a .25 and I’ve used it once. I may have a profile to share, would have to look. I think it’s’ on Makerword, not by me.
Yes, the fan from an existing BL nozzle can be used. You can also just purchase a new one if you wish.
The last is tough. The HF is nice and gives a little head room, but it’s not life changing. I can get increased flow about 30mms I stay conservative though.
So really you have to ask yourself, will I need higher flow? There’s a good bit of space between the prices, especially if you’re looking at multiple sizes. Quite honestly I’d say go ahead and get the HF for the headroom, but know it’s not necessary to get better performance.
Get a .25 if you think you’ll need to go that low in brass, the .4 in however you wish, and a HF brass or obx. You’ll appreciate the higher flow at .6 more than .4
Thanks for the info! This helps a lot.
@vhamly I totally understand why you are also confused with the Big Tree Tech Panda Revo High Flow Hotend.
I purchased BTT panda Revo Hotend, Panda Touch, Panda Branch, BTT LED upgrade and the Panda Claw all at the same time as when I purchased my P1S.
I installed the Panda Revo Hotend and right away I experienced a problem. :roll_eyes: So first off you have to make sure the wires are tucked away and clear the fan and hotend and also face the correct direction. Something BTT should fix either include a fan or set the wires in place. This leads to the second problem, with is the real problem. When you go to plug it into your Bambu Labs printer. If the cord does not line up just correctly with your printer it will give you a error message when you go to calibrate your printer. (I suggest when your installing it in printer remove the glass on top of printer and open the front door. Because you will need all the extra space you can get.)
As for the E3D Revo nozzles that is a whole other topic with in it self. It is kind of annoying that everytime you go to print you need to go into settings and change it to 35 - 40. (I normally just go with 37) But I wish that there was a actual way to either save it into system or Bambu Labs adds a update that allows your printer to recognize BTT panda hotend and automatically sets up the settings for you. Since there really aren’t any lists of setting files out there. So it’s kind of trial and error.
Then you have all the different E3D Revo Nozzles available currently there are 41 Nozzles available. (5) Brass from .15 -.80, (6) Brass High Flow from .40 - 1.4, (4) Obxidian from .25 - .80, (6) Obxidian High Flow from .40 - 1.4, (3) High Temp. from .40 - .80, (4) High Temp. Abrasive from .25 - .80, (6) High Flow High Temp. Abrasive from .40 - 1.4, (4) Diamondback from .25 - .80, and (3) Belt nozzles from .40 - .80. (But I don’t believe you can use the Belt nozzles with panda revo.)
With all these options it makes it very confusing what nozzles to purchase. Then add the fact that E3D doesn’t sell the nozzles you need in sets is really annoying. I am looking to get some E3D revo nozzles.
Also would like other peoples suggestions on what nozzles they would suggest and are the Diamondback nozzles worth the price? I have a feeling that E3D will be saying soon that they will be releasing High Flow Diamondback nozzles soon.
First, out of transparency I no longer use the Revo. It was ok, but the thermistor went in a blob and $55 or so for a replacement didn’t sit all that well.
I have since switched back to the E3D Bambu hotends. I had the Obxidian before the Revo and it was good. No great if you decided to push flow, not near what was shown. But it did produce nice quality and I liked it. I bought the Revo cause it was shiney and new.
Now I’m back to E3D and a Diamondback Bambu hotend. This is a tough one because I believe It’s stupid (I’m stupid) to pay such a price for a nozzle. However, it is very, very consistant and the quality is very good. I print a lot of abrasives and not having to worry is a great thing. It heats up quickly and holds temp. While it’s not “high flow” you can push flows up a bit.
Nothing sticks to it.
I’m sure the Diamondback Revo nozzle would behave exactly like it, I had thought about getting one.
EDIT if anyone cares. I’ve been using a Diamondback for awhile now (it’s 2026 now) and have decided I really don’t want any other nozzle. They are almost indestructable and print nice and clean. The Obx has turned out great too, including the Obxidian 500.
I chose the Panda Revo Hotend for the convenience part of the Nozzle. I like the fact that you are able to change it easily at anytime. Plus it has the nice bonus feature if you have multiple 3D printers it’s cross compatible with other revo hotends.
But I have to agree the prices for these nozzles are ridiculous. Plus none of them can really call themselves a real game changer. So it’s crazy for them to be asking these prices $180 for each Diamondback Revo nozzle for that price E3D should be including a warrantee on those nozzles that they will last for years and if you have any issues they will replace them. Otherwise they aren’t worth the price, Just wait till a chaper game changer hits the market soon and you will see companys like that tank we all know that will happen.
I doubt there will ever be a warranty on the actual nozzles unless you can prove it’s defective, and even then you have to hope the manufacturer will make it right. Be aware, since it got brought up, that BTT will not help you after their 90 day or whatever it is period. They do not care at that point. I know.
It sounds like you had a bad experience with BTT. But if you had Panda Revo issues E3D is also at blame even thought they pretend that that they don’t sell that product or treat it like it doesn’t exist. I can’t say that E3D is any better of a company. I contacted them about ordering multiple nozzles and they could careless. They acted like I was doing them some kind of favor. They were not helpful at all, really makes me question there company. With poor custom service like that.
Also I have a feeling that Bambu Labs and BTT are affiliated with each other or will be in the future. Honestly wouldn’t shock me to learn that Bambu Labs is the mother company. Seeing how they release a lot of upgrades that are directly for Bambu Labs 3D printers and right after the panda revo hotend collaboration came out with E3D, Bambu Labs released a version. Also Both Big Tree Tech and Bambu Labs are both located in Shenzhen, China says a lot.
Actually it seems Bambu tolerates BTT.
BTT is a company that loves to be consistantly inconsistant. They don’t care about it either. You may get a good product, you may not. They may help you in that window, but they sure won’t outside of it.
I have a Panda Touch. It’s rebooted and had issues off and on since launch. They sent another board for the dock that helped for a bit, but in the end it died. Because I was outside that window they just wouldn’t help, although it had been a known issue. Even through the betas connection and rebooting issues were reported. They offered me a 30% discount.
I am a sucker for new and shiney things. I’ve purchased most the the Panda stuff, well the useful stuff. I have a Fystec (sp) extruder gear set, didn’t need the horribly named “Claw”, the Branch intriqued me for future use, I already have a 24v tap. The PWR may have some use, as long as it keeps running. The light is horrible. The fan shroud is absolutely no improvement, or minimal. I keep that on cause I don’t feel like changing it and it doesn’t hurt anything.
As for E3D, not apologizing for them, but I never planned on contacting them if any issue other than manufacturing defect.
They’re just too many variables. I’m glad that I decided not to go with the BTT revo hotend. Although I do still have three e3d nozzles, and nothing to do with them.
I wasn’t interested in changing settings, i just wanted easier nozzle swaps.
I hope that the new Bambu Lab flagship printer will have quick swap nozzles
I bought the Revo with the 0.6 & 0.4 nozzles with the intention of adding the 0.2 nozzle to my work flow to add further detail to certain prints if needed. But after using them I instead decided to cut my losses, & revert back to the bambu hardened steel ones I had on my P1S (0.6) and X1C (0.4).
Perhaps my cranial hilbert infill isn’t the most intricate out there but I was under the impression that the Panda Revo setup was meant to be avconvenience that makes switching nozzles easier but not at the cost of print quality. Right? While it also promised improved flow and performance, I was more than content with the stock hotends performance wise. All I needed from it was the added ability to quick swap nozzles to elevate my already high quality prints. But it did pretty much the opposite.
Firstly it was painful to install. And I say that as someone who’s built over a hundred pcs and as a maker who works with his hands almost every day. The thermistor and heater cables are much too rigid and ‘girthy’ making folding and tucking them between the heatsink and fan assembly an extremely unwieldy and unsatisfying experience. And once you squeeze it in there somehow after a few rounds of the “lets see if I can simultaneously get my fingers out of the way and the fan in its place” challenge, you’ll find that the connectors are exactly annoying millimeters long. Which is to say they reach. But barely. I put the extruder cover back already starting to regret the whole thing.
Then came the Thermal errors during calibration. Did all the usual troubleshooting. Again I was under the impression the revo was just drop in and print. But I had to downgrade to an older firmware to finally get it to function. And when it did, the temperature readings were inconsistent making all my older filament calibrations invalid & new ones unreliable.
It took me a weeks worth of wasted time & filament to realize how much worse my prints had become. I’d had enough. I switched back to the bambu and haven’t looked back since.
I found it pretty befitting that REVO is OVER in reverse as I reverted to the stock hotends, so over the entire ordeal.
I personally don’t think that Bambu and BTT are related because in a post about third-party accessories and the new firmware Bambu said:
So I don’t think they are related. But it would be pretty interesting if they would work together in the future!
(BTW I’m not trying to attack your point, I think it’s perfectly valid, I just want to share my opinion as well.)
The only warning I have to people looking is the cost of a replacement heater core is half the cost of a complete unit. Otherwise, revos are solid.
That’s a sore spot for me too. That same 60w heater without the Bambu plugs is $34. I’ve already decided that if one of mine ever dies I’m going to solder the plugs on a regular Revo heater.
I know this is necromancy, but thought I’d share my findings too
I got the Panda Revo because I had revo nozzles from other printers - After a week of trying to dial in ONE filament and getting no where (0.4 Obxidian) I’ve reverted back to the stock hardened steel ones today, the convenience isn’t worth the loss in quality
I have spare companion boards, that’s the only issue with swapping nozzles on a x1 is the worry of damaging the board, it is what it is.
Where to start, long story short I share everybody else’s pain who has already posted here. Along with everything else mentioned above I had the thermistor plug completely detach from the motherboard (to be fair mostly my fault).
I replaced everything from the hotend, faceplate combo, gears and cage with Biqu parts. All in all a horrible experience and honestly there was nothing wrong with my prints in the first place.
I also have a stock X1C and the print quality is head and shoulders above my “tricked out” one. The initial install was such a nightmare I don’t have it in me to switch back, plus I spent a fortune on Revo hotends. Classic case of “if it isn’t broke, don’t fix it”.
That said I think a lot of people’s problems stem from poorly set up filament profiles and specifically MVF with Bambu’s “PLA” which by default the profile sits at 21 whereas the best I could achieve was 16.85, mostly lower with real PLA
I had the Panda revo printing about the same as stock in the end, but as soon as you start trying to build on that to improve upon it and say change something basic like wall/infill overlap it becomes harder and harder to maintain quality with it and I could never quite work out why
I tune my filament profiles as much as I can because I’m selling the things that get printed (not the thing in the photo, my point is the profiles are tuned) , here is an example of a tuned no name PLA with a tuned profile, no layer lines, perfect print, you’ll just never get to this point with the panda revo, but you can get to the point of getting it back to stock quality, but why bother when you can get the same quality with the stock hot end without pain?
Sadly I had a defective Revo HF obsidian nozzle the broke apart while printing. It was my 3rd time using it. Less than 10hrs total print times, and it was just over month old. They denied the warranty saying the don’t cover damage. I explained to the the situation and show them pictures. The threads came off of the nozzle. It was a defective nozzle. They have still refused to warranty it, I have spent lots of money with them and it unfortunately doesn’t help. And nether does E3D they are only offering 50% discount. Which is good but they are in the UK and I would end up paying more for shipping than buying another off of Amazon.
honestly after that experience I am not going to buy their products anymore. With over 200.00 in upgrades from E3D I’m am sadly disappointed with their warranty. And the over all customer service. They stop emailing back when I accepted the 50% discount… oh and they never sent it. I started the warranty claim in February and it’s now the end of march and I still do not have a obxidian 500 nozzle. I’m using brass until I find a resolution in my end. Buyer beware! E3D doesn’t honor their warranties
I feel you with BTT. My experience with E3D has been different though. I had the throat come off a BL Diamondback and they replaced it. I do not remember how far into the warranty I was, but it was a while. The OBX500 for the H Series is good, and the Diamondback for the H was supposed to be released today. That is from a Support email from E3D. I haven’t seen it yet though.
If you change your mind on E3D then use filastruder.com to order from. Quick US shipping that is either cheap or free (failing memory). I’ve ordered from them, they’re an authorized reseller.
