Panda Touch and Orca Slicer?
A couple of months ago on a whim I bought the BTT Panda Touch but I haven’t bothered to set it up yet. Pretty much the only reason I bought it was the ability to “control” up to 10 printers. I have 1 X1C, 3 P1P and 4 P1S printers.
I use Orca Slicer to slice models and send prints to individual printers over the cloud. My printers are in a separate room from my office/PC. How does sending prints work with the Panda Touch? I was hoping to just be able to send a print from within orca slicer the same way I do now, but just send it to several printers at once. Is that possible? Or do I have to actually use the touch screen Panda to send a print to multiple printers?
So in theory I should know the answers to this because I’ve had the touch hooked up for quite a while now… but I haven’t really explored the “group” function much. I just went researching and I found this:
If you scroll down to the “Group Printing” section it looks like it’s only possible with files stored on the USB connected to the touch.
Now about Orca, nothing will change once you hook the Touch up. Everything will look the same in Orca. After reading that though I do want to check out the group thing, I knew the Touch could control all your Bambu printers but I didn’t know it could do multiple at once.
Thanks, that’s the answer I was expecting but I hoped I was wrong and that somehow it would be possible to send a print to multiple printers from my PC. For me, that makes the Panda Touch a nice cosmetic add on but pretty much useless as far as added functionality.
True, the only thing I really use it for now is to update the filaments in the AMS after I swap them out so I don’t have to try and remember what I put where when I get to the other room where the PC is. Realistically I could use my phone for that too, or only buy Bambu filament lol. I want to believe that one day either Bambu or Orca will add the functionality to send to multiple printers in to the slicer.
It’s already there?
I use this quite often. It’s nice you can stager the prints so they don’t all start/ finish at the same time.
Interesting. I’ve never used Bambu slicer, only Orca from the start. There is a long standing request with Orca to enable multiprinter support, and it seems like if Bambu has implemented this it might not be hard for Orca to do it either.
Oh my god, when did they add that??
Edit Just found it on the Wiki… looks like 6 months ago lol. I need to start reading change logs when I update. As always, thanks for teaching me something @JonRaymond.
April 25th it released in beta.
May 13th as a public release.
It’s still a little handicapped in my opinion as it maxes out at 6 printers I believe. I really hope this is expanded at some point.
FYI
Click spool
Now that I did know about… unfortunately a huge portion of my filament isn’t Bambu. Change your desiccant, you’re in the danger zone! lol.
I’m aware.
I’m in the process of assembling an air dryer that holds about a gallon of Blue–>Pink silica desiccant which will then maintain a dry air positive pressure to my AMS’s. My nylon and abs I keep in a SUNLU S4 with the timer set to 99 hour run time.
PLA doesn’t seem to be bothered by it.
