Partially bad adhesion on first layer
I have partially bad bed adhesion. In this print I don’t care because its the bottom of a huge print and it will become okayish later.
The bed is cleaned with ISO before the print.
What can be the issue?
Clean with dish soap and warm/hot water. Explained why in the post below.
You have to use 3dlac and everything sticks.
May I ask how long you’ve had this plate?
approx 6 months. But its one of four plates which are in use.
Will try again with this, but it seems to be a filament issue.
I was having adhesion problems with PLA on a textured plate. After washing the print plate, I raised the bed temp to 65 degrees. I also slowed down first layer print speed to 20 (from 50). On small parts, I use mouse ears (on auto). This has solved this problem for me.
Edit: I have been using a PEI textured plate. When I first started using it, everything stuck without any problems. Now prints fail. I used the method above to get prints to stick. I have found another solution on this forum. I can’t try it now, my printer is down. The described procedure strikes me as reasonable and logical. I will try it and let you know. See link below.
Good Luck
