Ok, here are some results (the changes always refer to the initial situation in 1):
- Bambulab PLA-CF profile with layer thickness 0.16mm. Only change: slow down for overhangs is increased from 10 to 30 mm/s (for 50 / 75%).
- Random start / stop per layer.
- No slow down for overhangs
- Bambulab PLA-CF profile, also slow down for overhangs is kept at original values
- inner wall speed reduced to 200 mm/s
- acceleration for regular print reduced from 10’000 mm/s^2 t 5000
- same as 4) but with random start/stop
Conclusion:
The bambulab standard profile works best, which would be 4). The reason I initially changed the overhang speeds is because I had huge issues with printing PETG (see here). Changing the values completely resolved the issues for PETG, but as I see know are not recommended for PLA-CF.
Still: the seam looks not nice and I would like to improve that. 7) could be an option, but those tiny artefacts also show that something should be changed.
