Pause at Height or Layer Height
I have the need to pause my prints at a specific layer height to insert metal ID tags before resuming. On my legacy setups, I was using extensions in Cura, or editing Gcode for some printers that required non-standard Gcode commands to make this happen. Can you please tell me how to set a pause using your slicer? Or what Gcode commands does the X1C use for pause? & Add that capability if it doesn’t currently exist. I’d hate to have to go back to Cura & my old printers because of this.
Nice. It actually is right click on the plus (+) button now.
I’d like to see this improved. Coming from PrusaSlicer & Prusa, you can program a color change at a layer height. The LCD gives you a time estimate until the color change, beeps when its time, and then walks you through the color change. Its very friendly and efficient walking you through the process with confirmations.
Your wish came true: you can program a color change at certain layer also by right clicking on the plus (+) button. I’m trying that right now.
But I noticed already a pause might save a bit of filament. Because with an automatic color change you get these purge areas (built next to the model) that you won’t have if you pause the print and then initiate the filament change yourself (sure: also purge a bit of filament while changing but purge area is worse).
I am not sure if the latest firmware update fixed the bug, but there is/was a bug that caused a quite noticable layer shift if you used the +pause in the slicer. Instead as a workaround, try to use + → add g-code and add:
M400 U1
G28 X Y
What + button are you guys talking about? The only + button there is on the slicer is to add another filament but right clicking does nothing.
In Preview, move the vertical slider + button to desired height then right-click.
Oh man, you can really tell i just got off work. Thats the coolest thing, thanks!
Why would “Add Pause” be disabled?
I have a plate with two objects and I’m trying to insert a pause at the layer between the two objects to change filament. But the Add Pause submenu is disabled so I am unable to add a pause.
Any idea why it’s disabled? Sadly the forum won’t let me attach a screenshot or link
It appears that you can’t add a pause if you’re Print sequence is set to “By object.” Add Pause is disabled for By object, but it’s enabled for By layer.
Is this intentional? It makes it hard to change filaments between objects.
Hello, I have the same problem, when printing “by object” the menu is disabled…
I wanted it to stop the print when finishing the piece and remove it from the print base so it wouldn’t bother.
Same problem. Is there a logical reason for not allowing custom G-code like flushing the color between the objects or at least a pause to do it manually?
Now its always waiting for the specific layer and manually pressing pause to manually do the flushing.
Feels a bit stone age like, while the object ordered print itself is such a cool and futuristic feature.
Another workaround idea which just came to my mind: adding a small intermediate purge object. Might be helpful for others as well :slight_smile:
Have you did that ? please post back here .
Yes it works Well.
If you have Object A that you want to print in white and Object B which shall be black, you simply create a small object like a 3x3x3mm cube (Object C) which will also be printed black.
Than you simply order the objects A>C>B
tHANK YOU! I’ve been looking to use for some time but never found that hidden function until now! kudos !
Better late than never - I found myself wanting to do the same thing and asking the same question, and then made up the following answer. I think it may be intentional because adding a pause results in the print head returning to the home/poop-chute position and then back to the current object when the print is resumed. Navigating there and back with multiple objects of varying heights potentially already completed on the print bed could present challenges. I’m not saying it couldn’t be done - just that it could be a lot more complicated than going there and back in a straight line. I’m just guessing, though.
I am trying to add a pause at a very specific layer. But when I right-click the plus on the slider it moves down 2 layers. I can go to a specific layer, but then when I right-click it goes down 2 layers again. Is there really no way to add a pause at a specific layer without the right-click, like a keyboard shortcut? This is on MacOS.
I’ve run into the same issue on macOS. I haven’t found a fix when using the trackpad, but a reliable workaround is to just use an external mouse, which should consistently allow you to select the correct layer. Not an ideal solution, but I wanted to share it in case you’re still dealing with this.
Using Windows here. Right-clicking the vertical scrollbar “+” brings up options, but it does not move the slider at all.
The number of layers moved by dragging the slider via mouse depends on the height of the model and the height of the window. A tall model and a short window will move by jumps of multiple layers. A short model and/or a tall window may move by single layers.
Hovering near the slider and using the scroll wheel always moves by single layers. Or use the keyboard Up and Down arrows.
