Pauses at purge wiper after each layer
Doing my first print with the a1 mini. The printer goes to the purge wiper after each layer, pauses about 2 seconds and then continues with the print. Why?
My thought would be because of minimum layer time. If the part is small in size, it needs a minimum amount of time for the layer to cool before the printer prints the next layer.
Min Layer time would be nice, though, for me, it’s the optimized timelapse capture causing this. Did you try to turn the timelapse off?
Good call, I forgot about that option.
Might be that. I’ve tried to turn timelapse off but I suppose this doesn’t work while printing. It would be nice to be able to turn this off while printing to save printing time.
It is the timelapse function.
Just turn it off it saves roughly up to 15 min on a 2 hours print.
But how do I turn timelapse off? UI is not very clear about that.
When you send the print from Bambu Studio you will see a check box.
timelapse
OK what is very confusing is that there is no setting during Prepare, only a selection between Timeapse Traditional or Smooth. It would be more logical to have an off option there as well.
I just turned recording off in settings.
After I turned off timelapse, it worked correctly too.
That don’t make sense. Camera is on the left. Therefore extruder needs to travel to the right to take a pic of the model.
I don’t know about other Bambu printers, but the camera of my A1 is located on the right side.:smile:
I have to use this trick to prevent the wipe action, even though I turned the time-lapse mode off, by modifying the Layer Change G-code to {if !spiral_mode && print_sequence != "by object" && 0==1}
Are you saying to modify the “Layer change G-code” or the “time laspe g-code?”
I just checked and that exact code you said to modify the “layer change g-code” to was the first line in the “Time lapse G-code.”
I am still seeing the layer paths diplayed during preview even though I have timelapse turned off. I would like to not have that happen and also wonder if what I call the “phantom travel paths” add to the print time estimates.
Try formatting the sd card. It worked for me
