Pausing print to change filament
Hi,
In the past I’ve used the insert pause to change filament without an AMS. and this has worked without any issues. Today, after the printer paused I selected ‘unload filament’. The filament was unloaded but the printer hangs on the unload screen. I managed to continue the print by changing the filament and doing a number of continue/pause stages using the handy app. The print turned out OK. I’d like to resolve this issue.
After this I should say the printer asked me if I wanted to update the firmware and I selected yes. So I can’t say if the new version has already fixed this. Only time will tell.
Hello,
I have the same problem. I use this method to change colors. The issue is the same when I insert a pause in the G-code.
My firmware: 01080100
Please Bambulab team help us !
