Pay attention to clicking noises - you might have a problem
I just learned a new lesson.
When you unload filament, if you are not at the ready when the extruder starts ejecting it then you will hear a clicking noise. This is just the end of the filament touching the extruder gears as they spin trying to push it up. This does not cause a problem.
A strange thing i wonder if anyone else has noticed, is that when the tool head gets to the home position and just before it starts pushing the filament up, it actually pulls the filament in slightly. Just an odd observation.
Now for the problem. Many of us have created a post talking about printing air. This happens if for some reason the extruder cannot move the filament. Because the filament sensor still sees filament, the extruder keeps trying to push filament through the nozzle.
I have had this happen for several reasons.
  1. the spool runs out, but the end of the filament was anchored to the spool so securely that it will not come loose.
  2. the end of the filament comes loose from the spool, but it has a very severe kink at the end and cannot be pulled through the guide tube.
  3. somehow the filament gets tangled and the extruder just cannot pull any more filament from the spool.
    I would guess there are some additional cases caused by the AMS.
The problem is, as long as the filament run-out sensor sees filament going in to the extruder it does not care if it is not moving. I have had the printer print the first 5 minutes of a 2 hour print and then keep grinding for the next two hours while printing air.
When the extruder is grind away on some filaments the filament is soft enough to just shred. This causes a mess in the extruder that needs to be cleaned up.
In other cases, such as the one that just happened to me, the yellow extruder gear is the weak point and starts skipping. The drive gear is steel and it will slowly abrade the teeth of the yellow gear. This is the clicking that you do not want to hear.
It took me quite some time to find the problem. I disassembled the extruder at least three times. What made it so hard to find is that the damaged teeth on the yellow gear are barely shaved and it only affects the tooth at the slipping point. You can unload and reload new filament and it seems to work fine, but when the yellow gear gets to that tooth the filament stops moving and you hear the clicking.
My suggestion is when you hear a clicking and the filament is not extruding look at the yellow gear through the window in the side of the tool head and see if it is turning. If not then you have the problem.
I also notices when cleaning the extruder during the early part of troubleshooting, there was a tiny piece of filament stuck down in the steel gear that drives the yellow gear.
I am waiting for a new extruder and a new gear set (double redundancy) and I thought maybe I could help someone recognize the problem before parts got to damaged and needed replacement.
My parts came today and I am up and printing again. I just thought I would provide a little more info for those ordering parts.
Stainless Steel Extruder Unit - P1 Series
This is a complete extruder ready to bolt in. It includes the three screws needed and for some odd reason a tube of glue. I can’t imagine anyone would want to glue the connections that they are going to have to take apart again.
Hardened Steel Extruder Gear Assembly
This is just the two parts that have the hardened gears that grab the filament.
I’m new here and hope you don’t mind me sharing by quoting you, I use silicone glue a lot to hold wires in place as well as JST connectors. It’s sufficiently strong but easily peels away, it’s purpose is to eliminate any chance of your connectors and cables coming away.
I think that if you’re printing from AMS, then it detects that the filament is not moving. That’s why you might a “filament swap” action even if only one filament is used. That’s a sign that the motor isn’t able to push the filament in.
Not 100% sure I am right when it comes to clogs, I know it works like this if the spool is tangled or your PTFE tube breaks and the filament gets stuck. AMS has an odometer.
Why I’m not sure that it also works for clogs is because of the filament buffer, I don’t think that one has an odometer (which is a shame)
Thank you very much for sharing, what drive me crazy is that when I hear this ugly sound .. I pause the print heat up the nozzle to 250 and manually extrude .. and dose very well .. no ticking .. no problem .. then I resume printing .. it works for a few minutes then I get that sound again .. what really helped is that I increased the print temperature to 230 from the recommended 220 .. it still ticks a little but much better.
I also noticed this happen with a the spools that’s half used and kept in storage for while .. even is there is a kilo of silica in the bottom of the sealed container .. for some reason .. those half used spools cause this problem .. a new spool works perfect.
On last thing .. I don’t know if the “retraction” cause a similar sound ?
Thank you again
Just a quick update .. I installed a new, longer filament tube .. and it fixed the problem completely .. it now works very well .. thanks
