PETG-HF - white; highly detailed print
I ordered PETG-HF the first day it became available, and has since made multiple prints for red and black. Although I haven’t done any testing as such, it’s pretty clear to see that PETG-HF must be dried, but provided it’s dried sufficiently as described on the product page, it’s also clear that it does indeed perform very much like PLA in terms of surface quality and printability.
Yesterday, I made this print with the white PETG-HF, and the result speaks for itself:
This used a print profile with speeds up to 300 mm/s. There’s a lot of z-hops too, steep overhangs and of course, a lot of very small details that my 0.4mm nozzle has only been able to deliver with PLA in the past.
But now PETG-HF is also an option, and I’m beginning to be hard pressed to see why I should order PLA at all, except for the colors not available in PETG-HF.
So here’s a wish to Bambu Lab: Please make more colors available in PETG-HF, so more things can be printed in it - because although PLA is most often a good choice for non-functional parts, with PETG-HF we don’t have to worry about placing our stuff in places where the temperatures may get high.
i ran into a problem when printing petg-hf
a very new (just out of the box) petg-hf is damp and when i was printing there were blobs :worried:
Try 6 hours at 65 ºC.
Any and all moisture issues that people experience with PETG-HF, is their own fault, since Bambu states very clearly on the product page that drying is a must.
I realize that not everyone have filament heaters, but 60 ºC in a household stove is fine too (I suggest 60 to avoid heat spikes becoming an issue).
much gratitude :smiley_cat:
i feel just confused because it seemed that the filament was damp out of the box :rofl:
I just got two rolls of PETG HF, one black, one white. I tend to dry all the filament I get regardless (I have the Sunlu S4 making this easy) and my experience with the PETG HF says drying following the drying directions and temperature from Bambu is necessary.
I dried both rolls for 12 hours at the same time and ran a test print on each, the black looked great, the white had tell tale moisture bubbles in the surface. I put the white one back and realized I had the dryer set to 60C instead of the recommended 65C so I upped it and did another 6 hours. This time, the white test print had no bubbles.
I have not been a fan of PETG in general, with the exception of PETG-CF (which I tend to use TINMORRY brand) however I’m going to give a thumbs up to this new PETG HF filament as the results are both high quality and less shiny (I prefer that, if I want shiny I’ll use silk)
I ran my own Orca Slicer profile and the only change I made to the Bambu profile was the flow ratio which I ended up with as 0.9875 and increased the volumetric speed to 25 as the flow test showed it had no problem hitting that (it went higher but I don’t want to push it)
In comparing to PLA, the area I notice the biggest difference is in overhangs but it does seem better than regular PETG. If anyone has tweaks to improve PETG-HF overhangs I’d love to hear them.
I go very, very slow with overhangs. As in 10-25 mm/s slow. I also try to place it on the build plate, so I get the overhang part close to the chamber fan. It gives me pretty perfect overhangs.
Apparently they don’t pre dry the rolls, they just seal them with a desiccant and ship them. I’m not sure if they are actually drying them now because I’ve had no issues, I mostly use black, but green and red came out flawlessly.
What temperature are you running your white PETG HF at? I’m having a heck of a time dialing mine in. I’m doing a two colour, black and white coaster. The black seems to print OK but the white eventually will clog without ever finishing the print. Presently working on a 255C first layer which goes down good and have been working up from 240C for subsequent layers. Sometime will get 60% through a print before clogging occurs. Sometimes happens after a few layers. Filament dried for 12 hours at 65C. Cold pulls performed after each clog.
@kevinhenryjohnston - Assuming you are running with an AMS, what is the humidity it’s reporting and is the PETG HF spool in there?
Running in AMS with fresh desiccant. Reading is at 1 in Bambu Studio. Presently working on a 265C first layer with subsequent layers at 270C, the maximum recommended by Bambu. The last test got down a layer of white and black and then clogged again. It was printing at 260C first layer and 265C for subsequent layers. If that doesn’t work I’ll try again tomorrow with two new rolls that I just put in the dryer. 65C for at least 12 hours. Wish me luck:) I will eventually get it.
Good luck! :+1: . . . . . .
I run 230 ºC on first layer, then 245 ºC on subsequent layers. This goes only for PETG-HF (but I do use the same profile for white as for black and red). I have never had a clog with PETG-HF - and I’ve fully printed 5 rolls now, and half of 3 others. Only black, white and red - although I have other colors lying in wait…
I run other types of PETG hotter - clocking in at 255 ºC.
I usually do 50 but 65 should work
Out of curiosity have you ever printed PETG-HF in orange? For the life of me I can’t get this stuff to print well - especially overhangs. Would you mind sharing your tweaked settings that you’ve found to make this filament print best? (ie nozzle, bed temp, speed, etc)
TIA!
