PETG Matte not showing in Studio for A1 (AMS Lite)
  • Printer model used
  • Slicer settings used
  • Type of filament used
I’ve been running my A1 combo for just under a year, and things have been fine, BUT…
Just taken delivery of some PETG Matte and it’s not available as filament in Studio. The AMS reads it as “unknown or incompatible”. The store page says it’s compatible.
I can’t even run a calibration from Studio as it grey out they spool and says “Incompatible”.
Printer is running 01.08.01.00 (Latest)
AMS lite is running 00.00.08.15 (Latest)
Studio is 2.7.1.62
Pre-sets config is up to date.
Anybody dealt with this?
EDIT. Had a look in the spools.json and the matte is showing..
“tag_uid”: “”,
“tray_id_name”: “”,
whereas the other spools (PETG Basic & PLA Basic) have their tag and spool location listed. Doesn’t explain why i can’t select it in Studio though ??
FIXED IT!
I needed the beta release of Studio for it to recognise it. Panic over :slight_smile:
You don’t need the Beta, you likely just needed to add the filament to Bambu Studio. It has been available for months.
That was the problem, I’d gone to that page after following a few guides and the PETG Matte option wasn’t there.
Printing with it now, just getting terrible nozzle blockage with it, tested with some PLA Basic and the prints went fine.
In fact, I couldn’t have timed it better when I mentioned the blockages…
Latest blockage is with brand new out of the pack 0.4mm Bambu nozzle, still clogging up.
You probably didnt need to switch to beta, but chances are you were not on the latest version of studio.
I havent tried it personally, but from what I have seen here, the filament needs to be dried. It does not have anywhere near the resistance to water that bambu advertised
Did you dry the filament first? I just completed a test on my H2C with no issues. I’ll move the spool over to my A1 and see if I have any problems there.
It came out of the bag and went into my drier for 24hrs before i used it.
I thought i’d done everything right to protect myself against this sort of stuff.
It gives me something else to grumble about i suppose!
:+1:
My A1 test print looks good, I don’t print PETG on it very often anymore so I am happy with the results.
I’ve personally never used a tool to clear a clog, I’ve always used cold pulls, multiple, if necessary. You mentioned swapping nozzles, double check it’s snapped in good and correctly. Maybe open the tool head to see if you have a small amount of filament jammed.
My picture taking skills suck, and I hate the iPhone camera… :confused:
Please edit the post title if possible with (fixed) as other users might come to your post directly and find the solution.
HAPPY printing
Had a look around the settings, but there’s nothing available. I’ll add a header to the original post.
Might help somebodies blood pressure in the future. :+1:
edit, turns out there’s quite a short edit window on this forum, so i’ve selected myself as the “solved” answer, it’s good for my ego.
That cube looks crisp!
I’m thinking of chucking the spool back in my drier for 48 hours and give it another go in a few days.
Be careful with that, you can over dry filament. Bambu recommends 12h @ 65C. 48 hours is way to long.
Thanks. My cheapo drier only gets to 50c at max but i’ll shorten the time.
This makes sense; you are probably still dealing with wet filament.
If you decide to look for something different, I have a buddy who pre-ordered the Sunlu AMS Lite heater, and he is very happy with it. It’s a good solution for printing while drying on the AMS Lite.
