Hello everyone, I have the problem when printing with PETG that the filament does not stick to the edges/corners and unsightly areas appear, as can be seen in the pictures. Can you help me to find a solution?
I print with ERYONE Transparent PETG at 240 degrees. Print bed 70 degrees and a speed of 60mm/s for the first layer. The cooling is off for the first 2 layers. I dried the filament before. Adjusted the flow and leveled the print bed.
For me, it looks like you touched the plate with your finger and left some residue. With such a large print, clean the plate with IPA and dont touch the area where the print is.
It could also come from the fact that near the tab, the temperature is a bit lower, it can easily be seen with a thermal camera, try to use a higher bed temperature (80/85)
EDIT : also slowing down first layer print infill always make sticking better.
Bambu support recommends to use soap, but I agree with you when it comes to additives. I have success with Palmolive liquid soap, good enough to remove skin oil form handling the plate without gloves and any residue of the glue stick. Isopropyl seems to have damaged the Bambu PEI coating in the past, not sure if this is more of a rumor or true.
