PETG together PLA
I’m new, and I don’t know if my question is too obvious. But is it possible to print a model with two different filaments, in this case PETG and PLA? Regards.
PLA and PETG do not stick to each other. So much so that you can use them as support material for each other and get a nice surface at the interface.
Thanks :wink::+1::+1::+1::+1::+1::+1::+1::+1:
Thanks :wink:
In general you can’t, due to different requirements (e.g. bed temperature). But as blchandl2 said, PETG is often used as support material for PLA and the other way round. You can also use this only for the layer between support structure and model body.
With the H2D you have a little bit more options, but the main blocking point stays the same.
