Recently discovered, on a failed print for other reasons, that my outer shell layers aren’t adhering together, creating vertical planes sheets. Is it normal, if not, the part was… fine, but I am questioning if I should try different settings to solve it.
try to post a photo please
Separating easily between layers? Too high of part fan speed?
I can’t, I thrashed the parts. But it was really like each layers adhered well vertically, but laterally they didn’t, but it wasn’t under extrusion it seemed because the lines were still filling the space.
Maybe it’s too high cooling fan. I have no idea.
Felt strange.
Here is an example in PLA matte, I think
See the corners the lines are separated from each other by a gap and don’t adhered to eachother.
Temp 24C, humidity 29% in the room (was stored at 18%)
Have you checked to see if it’s the model?
