Piece print setting
bonjour,
je souhaiterais pouvoir enregistrer des paramètres d’impression d’une pièce et pouvoir les faire basculer sur d’autre pièces comme les objets!
exemple: modificateur spéciaux pour ponts, mains suspendus ou bâton fin , texte ancré, tête suspendus?
Hello,
I would like to be able to save print settings for a part and apply them to other parts or objects!
For example: special modifiers for bridges, overhangs or thin pillars, anchored text, or overhanging heads?
This is already possible - but it isn’t very intuitive and could be improved, I agree.
You can set unique settings for each item in the Process menu section by clicking Objects rather than Global.
Once unique settings are established, you can right click and item and select “copy process settings” and then right click a target and select “paste process settings”.
Using this, you can have a designated “template file” with a plate full of objects, and each one has unique settings that you can copy and paste onto the actual item you’re printing.
So along with “copy process settings” and “paste process settings” it would be nice to have “save process settings”.
thanks!!don’t understand this.
but not just as
when exist many print, saving in bambu studio,
when open, ask!! not erase all settings
