Pin Assignment AMS 2 Pro
Hi,
can someone give me information about the pin assignment of the connector - especitally GND and 24V?
Thank you very much! I´m planning to use 3 short addition 5V LED stripes with in sum about 7W and I would like to use the 24V and GND from the AMS connectror. I will add a fine fuse on 24V side and an electrolytic capacitor well as an ceramic capacitor to save the electonic of the printer if my buck converter emits high frequencies… do you think that´s a practicable way or would you counnect the LEDs with the PSU?
I’m sure it will work fine but why not use 24V led strips? Bambu Lab specifically advise against it though: Bambu Lab Mods to be cautious about | Bambu Lab Wiki
On my P1S I used neither I added a 5V power unit directly from the mains (it’s integrated in the printer because I had room to do it :slight_smile:
Ich wollte kein weiteres, externes Netzteil wegen 7W laufen haben… vermutlich wäre das aber die sicherere Variante. Ich denke darüber nach, trotzdem Danke für die Info zu den Pins!
