PIP Side Panel Screws
It appears that screws are going right into the printed side panels to attach the panels to the frame. What kind of screws are these? I’m surprised since I normally wouldn’t screw into the plastic, but would use heated inserts.
I’m looking for the same info, I dropped several of them and they have disappeared so I need replacements.
FWIW, I broke out the digital calipers and measured. They’re M3 screws, looks like .5 pitch, 5 mm long and 2 mm Allen key. I ordered a bunch from Amazon, we’ll see how they work out.
Did those M3 you ordered work for you?
Yeah, they worked perfectly. Plus I’ve put some of the others to use for other projects.
Search 720PCS M3 Hex Bolt Screw Assorted M3x4mm 6mm 8mm 10mm 12mm Black Alloy Steel Pan & Flat Head Hex Socket Screws with Plastic Box
Amazon’s Choice for “m3 flat head screw”
