PLA Matte Dark Green mislabelled?
Just received my spool of PLA Matte “Dark Green”. I love the colour, but I think the colour is mislabelled? It really is more a “Olive Green”. In fact, it’s nearly identical to the “Olive Green” from eSun. See the attached picture.
Hey @BambuLab , you should probably change the labelling on this filament as to avoid confusion. Doing it now is going to be a lot easier than doing it later.
Umm, it says “grass green” in the EU store?
Also there’s a HEX color code you should be able to compare with?
Matte Grass Green (HEX Code #61C680)
Grass Green is a different colour completely. One is available as a refill only, and the other as with-spool only. You might need to select one type, and the other, to see the full range of colours.
And, yeah, I think that’s a silly thing to have to do.
Ah see it now, sorry for the confusion.
It does seem to more or less match the hex code though. If that should be labeled “dark green” is a very valid question.
Probably a translation artifact. I’ve learned from many years of buying ribbon (ex-wife’s hobby) that color names can be quite misleading.
True, that. Still, it’s very obviously olive green :slight_smile:
