I wanted to make handle for my sprayer. However after printing i saw tat it leaks under pressure. All tutorials on youtube cover water leaking without pressure.
I use PLA nozzle 210ºC buildplate 60ºC layer height 0.2mm nozzle 0.4mm.
Though I’ve not tried this, I think a scarf seam joint might help by overlapping the filament at the seam position. Turn on the Advanced Process settings if you don’t see the option. Use contour and hole, Order of walls- inner/outer/inner, slow the outer wall speed. This should also make the seam nearly disappear and improve the appearance.
Try dipping it in acetone, let it dry and repeat. I did that to make vase mode floats water tight. I’m not sure if it will work for the pressure you have though, the process will work better with ABS.
I haven’t had much success leak proofing PLA with acetone. I’ve had more luck when I painted a PLA print with an epoxy coat. I’ve also tried clear nail polish with good success.
@woj_now have you considered trying to print the part in ABS and then dipping it in acetone. This is the best way I’ve found to seal up the layers.
