Plate Cleaning P1P ~~ TOO STICKY
Hi,
I have a P1P. I cleaned my build plate with alcohol wipes - per instructions on a YouTube video.
Well NOW… it’s too sticky, meaning that I am having a very difficult time removing prints, even after I shut the print off for several hours. I have to take some tools and try to pry the print off the build plate.
For the record: I am /do not use any types of adherent chemicals. I just print it.
Any thoughts???
Thanks,
AJ
What plate?
What filament?
What I do… If I find a specific problem, “Plate too sticky” I address that problem. First would be to wash the heck out of the offending plate to see it that can help. (And avoid eating a PB&J around my printer) :wink:
Second would be to try a different plate. At this point I have my original, and my second plate which is in use. So I could switch plates to see how the old one works in comparison. If it were to be too sticky, I would suspect it is something I had messed up in changed settings. (Operator errors, it happens, no shame.)
But the fastest cure would be to substitute a plate. My new plate is being held hostage by Amazon as we speak. Due Wednesday. But the biggest reason for my newer plate is for substitutions. Pull the hot done plate, put in the other plate and continue printing, while I deal with the removed plate. IE: More spiders per hour keeping the printer running.
But substitution plates is a good first step in troubleshooting.
let’s bet. PEI plate, PETG :joy:
Hi,
FIRST - Thank you for your reply
SECOND - Yeah… I did not realize you’re supposed to use different plates for different filaments.
Yeah… whoever said I am using a PEI plate with PETG wins the Forum Helper of the Day Prize
So… what plate should I used for PETG?
Thanks
AJ
Bambu’s documentation has always been very clear - soap and water only.
This always devolves into a fight, but OP, follow Bambu’s recommendation and see if you still have a problem.
I use the textured PEI plate for PETG but have found very thing things like skirts/brims are annoying to remove. Sometimes throwing it in my freezer for a few minutes alleviates that too.
I have no plans to stop using that plate, I just very carefully pick the stick parts off with a dental pick, trying very carefully to not grab/damage the PEI.
Is there a special or dedicated plate for PETG?
My guidelines:
  • Bambu Smooth and Textured PEI: glue for all filaments except PLA.
  • Bambu Engineering: glue for all filaments
  • BIQU Glacier: no glue, except possibly for large PA models to resist warping.
Be patient; allow prints to cool if they do not release easily. Super-stubborn prints go in the freezer for 10-15 minutes.
Right. Alcohol only moves the oils around, use a good dish soap and hot water. Rinse well.
default pei plate grabs too much on PETG. It’s not a bambulab feature, it happens on all printers.
(all my peis are all damaged except the geeetech M1 because i don’t print petg there)
buy a glacier plate.
I am impressed by G10/Garolite plates.Both ABS and PETG do well and once the print is complete I just watch the bed temperature on go grab the model without touching or moving the build plate.
Alcohol also absorbs moisture. I realize the plate is normally hot or heated on the bed, but the ouchmehol does do more than remove sticky finger goobers. Generally, I try to avoid touching the printing surfaces.
No, no, no… I don’t use alcohol on a hot plate.
I used alcohol to clean the plate after it was cold.
