Please explain hueforge to me
Is this just separating into CMYK and then making one print for each color, with thickness depending o the color strength? Or is there something else I am missing?
Hueforge is in fact a software which allows you to create detailed multi-color 3D Prints using what’s called swap-by-layer. It isn’t like a slicer or a painting program, but it generates a stl model file for you, based on the image you worked on. It also generates a text file showing the layer heights at which you are to make filament colors swaps. Obviously, using an AMS helps and speeds up the printing tremendously, but then again, most makers don’t have this, so they do the filament swap manually.
HueForge Software is closed source. Is there an Open Source alternative?
Autoforge: GitHub - hvoss-techfak/AutoForge: Autoforge takes a picture and generates a 3D layer STL file that you can print with a 3d printer
Lithophane (not quite the same)
Thanks for the pointer to AutoForge.
There is also chromaphane which software like lithophane Maker will do and there is PIXEstL which is free (but not hueforge) and may have a higher learning curve. I have looked/played at both but not really done any printing.
