Please make the setting for wall order settable via a modifier
When making an object with small holes it is better to reverse the wall print order so that the hole doesn’t get “squished” by the outer wall when it print second. However if that same object has a outer edge with a fillet or curved outer wall you really want inner/outer. Right now I cannot see a way to do this without splitting the object into two parts because the setting is per object. If modifiers included this setting you could put a modifier around the holes and set outer/inner while leaving the outside wall of the object as inner/outer.
This feature will be helpful to have.
